ESP8266 driven Air quality monitor fetches data and displays via NeoPixels
ESP_AirQualityMonitor.inoThe code currently running on this ESP8266 Will consider using micropython instead.ino - 5.23 kB - 01/12/2017 at 03:05 |
The NeoPixels render the web colors very bright, using unnecessary amounts of power and also a bit ambigous - so I might select some more appropriate colors and rather rely on the index value for the different values.
However, at the moment my primary focus is to make a nice enclosure.
Will add some 3D files, feel free to comment. The idea is to try to mill this from aluminium using my OtherMill, but I have not really mastered 3d milling yet...
