Reference base for PPSTrigger V1.2
A project log for PPSTrigger - USB PD Trigger SuperCharged with PPS!
A much simplified USB-C PD and PPS trigger board. Allow users to select arbitrary voltage from PPS-capable power brick via potentiometer
centylabCentyLab 01/23/2025 at 07:390 Comments
Here is the reference base design for the PPSTriggerV1.2. Combine with a small digital multimeter, you can have a small portable power supply where ever you go!
Download the STL file for the base here.
