The TEC-1G remains true to the original TE design goals: it is is built using only simple through-hole TTL logic chips so it is easily built and understood by the hobbyist. For the first time, the TEC-1G will also be fully free and open source, in both its hardware and software. The TEC-1G is the ultimate TEC-1!
The 1G has been developed by Mark Jelic with the input of the original designers, John Hardy and Ken Stone, ex-TE staff member Craig Hart, along with contributions from community members Brian Chiha and Ian McLean. Finally, the 1G has also been produced with the blessing of Colin Mitchell, Talking Electronics owner.
Major Features
- Full TEC-1 hardware and software compatability; runs all previous MONitors without modification
- Flexible memory options; 32K RAM, 16k ROM in default configuration. Up to 64k RAM + 16k ROM supported.
- Support for multiple configuration options and memory types from 2k to 32k memory devices
- RAM write protection for improved software development
- Shadow Memory and bank switching capabilities
- 20x4 LCD screen as primary display device
- Diagnostic & LED bar indicator for system state
- Z80A CPU running at 4.0MHz; 'slow' clock support for older monitors retained
- Full QWERTY MATRIX keyboard & joystick options
- Upgraded key options for onboard hex keypad; supports Gateron Low Profile switches with optional backlighting, as well as standard 12mm tactile buttons
- Improved RESET circuit for reliable start up and system stability
- Serial interface using an optional FTDI/FT232 adaptor for USB communication with a PC or terminal
- Future support for SD card mass storage interface
- Native Z-80 expansion bus connectors supporting a full range of peripherals
- 'TEC-Deck' expansion connectors for future daughterboards
- 'TEC Expander' port for compatability with existing TEC peripherals
- HALT status LED
I'd like to thank PCBWay for sponsoring the ongoing development of modules that are being added to the TEC-1G ecosystem. I'm impressed how proactive they are in finding projects like this one and encourage and foster such development. Thank you, PCBWay!
Mark Jelic
gbm
Blair Vidakovich
Tomeu Capó
