First run:
I couldn't find anything good to wind on. It starts well for the first 10 turns or so then skips and then is all messed up.
The movement in the background is the backlash compensation nut on the X axis. (Needs adjustment)
The noise is from the wire spool rattling on the makeshift axle, not coming from the machine.
Overall not too bad. I'm sure it could be made better with enough tweaking.
