- Follow the Raspberry Pi guide to install Home Assistant Operating System.
- Access Home Assistant at homeassistant:8123 or "http://X.X.X.X:8123" (replace X.X.X.X with your Raspberry Pi’s IP address) and log in management page.
- Install the ESPHome in the Add-on, the detail you can click here.
- Configuration relay.
- Set up Automation as shown in the figure, and select When a Webhook payload has been received as the trigger condition.
