Final Assembly
A project log for Commodore CHESSmate Reproduction
The plan is to make a reproduction of the dedicated chess computer CHESSmate released by Commodore in 1978.
michael-gardiMichael Gardi • 03/14/2024 at 16:35•4 Comments
The new and improved backpack PCB arrived. Better late than never I guess. I started by soldering on some headers.
I soldered a couple of female straight headers to hold the ESP-32, a couple of male pins to connect to the +5V and GND on the ESP, and a 90 degree Female header to attach the backpack to the CHESSmate PCB. In the rightmost image I have mounted the ESP-32 onto the board.
With the backpack ready I attached the stack comprised of the:
  1. Membrane
  2. 3D printed standoff with cutouts for the displays, LEDs, and buttons
  3. CHESSmate PCB
to the case with eight M3 x 14mm bolts.
Then I mounted the backpack CPU.
Once it was in place I connected the micro USB connector power leads to the backpack PCB and mounted the piezo speaker to the case with two sided tape.
Popped the bottom of the case on, applied power, and viola a working CHESSmate reproduction.
svofski wrote 03/20/2024 at 09:39 • point
Nice! So the membrane is flexible enough so you can push the switches through it without overstretching it?
Michael Gardi wrote 03/20/2024 at 11:34 • point
Yes it seems to work pretty well. The push buttons are a couple of mm above the frame which helps I think. We’ll have to see how it holds up over time but it’s easy to replace.
Cees Meijer wrote 03/20/2024 at 08:18 • point
Looks great ( as always) !
Michael Gardi wrote 03/20/2024 at 08:38 • point
Thanks Cees.
