What's that saying... measure twice, 3D print once?
I am not feeling energetic today so I just did the simpler stuff (3D design/printing).
I added lens caps as well since the original lens covers won't work with the front plates.
Each lens has 3 parts to print between 2-3 hrs on avg, so it'll take a while.
I printed 2 for the 35mm today, it was almost bad but I just cut some of it off (too tall).
Lens cap for 5mm Sonew lens
Aperture ring for 35mm Arducam (this is very narrow it turns out like a 100mm full frame equivalent), the 5mm above is more like a 35mm on full frame
Started thinking about the menu
I won't be able to write any serious code again till Christmas working 5x10 shifts damn
The 12mm Arducam lens will be my macro since for some reason it can't focus farther than that. I tried an adapter but that made it worse. Works for me since I like macro/where I live is boring.
