I really like this shot, it's landscape though, can't use in main thumbnails
Tried my hand at "birding" ha, need higher lens numbers
Best shot I got with Arducam 8-50mm
I need to work on color profile stuff/actual manual camera settings
Software is buggy too, had to turn it on/off few times
Aberration I think is what's bad here
The battery profiler I'll wrap up tomorrow.
There is still a major refactor that needs to be done with regard to how menus are grouped/composable
The battery thing I also have to test the charge question/do the actual profiling for my setup (Panasonic 18650B 3400mAh 4.9A protected)
Hopefully will get my RODE mic in tomorrow and use that for the brief code overview for battery
Jacob David C Cunningham
