Alright I'm done with 3D printing stuff... I was lazier on the 12mm and have had to make either physical changes or reprints. For example the lens cap had a smaller inner diameter than the barrel's outer diameter so it wouldn't fit... dumb. Reprint at least that is under an hour.
The 12mm is shorter so it looks more "camera-ish".
I am working solely on the menu/camera software now. I look forward to 3 days from now when I'm off again.
I may have been wrong claiming this as a macro camera, it's just super cropped. I think macro has magnification.
Some shots, a China doll plant leaf and a dragon fruit (I grew from seeds)
This is still using the non-zoom-crop-pan method, just a scaled down 128x128 preview of the 4000x3000 image.
Jacob David C Cunningham
