Step 3: Result
From the video, you can see that the resolution 1024 version has higher display effects, while lower FPS, and the resolution 800 version has lower display effects, while higher FPS.
The result is that the high-resolution version is better suited for static displays, while the low-resolution version is better suited for dynamic displays.
So which version do you prefer?
