- The MaTouch ESP32-S3 Rotary IPS Display with Touch 2.1“ ST7701, with rotary encoder.
The rotary encoder and its pressable operation are perfect for making a combination lock. The rotary encoder controls the value change and the pressable operation is used to confirm the code.
- LED_RGB
- Software support: Arduino, SquareLine
