The MaTouch ESP32 S3 2.1 Rotary TFT with Touch is not compatible with the TFT_eSPI library, so I use the GFX_Library_of_Arduino library instead of the driver.
- Since I did not use the TFT_eSPI library, it is needed to delete or comment all the codes related to the TFT_eSPI library.
#include <TFT_eSPI.h> TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */ tft.startWrite(); tft.setAddrWindow( area->x1, area->y1, w, h ); tft.pushColors( ( uint16_t * )&color_p->full, w * h, true ); tft.endWrite(); tft.begin(); /* TFT init */ tft.setRotation( 3 ); /* Landscape orientation, flipped */
- When I use the GFX library, it is needed to define the GFX Library For the Arduino Interface pin.
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel( 1 /* CS */, 46 /* SCK */, 0 /* SDA */, 2 /* DE */, 42 /* VSYNC */, 3 /* HSYNC */, 45 /* PCLK */, 11 /* R0 */, 15 /* R1 */, 12 /* R2 */, 16 /* R3 */, 21 /* R4 */, 39 /* G0/P22 */, 7 /* G1/P23 */, 47 /* G2/P24 */, 8 /* G3/P25 */, 48 /* G4/P26 */, 9 /* G5 */, 4 /* B0 */, 41 /* B1 */, 5 /* B2 */, 40 /* B3 */, 6 /* B4 */ ); // Uncomment for 2.1" round display Arduino_ST7701_RGBPanel *gfx = new Arduino_ST7701_RGBPanel( bus, GFX_NOT_DEFINED /* RST */, 0 /* rotation */, false /* IPS */, 480 /* width */, 480 /* height */, st7701_type5_init_operations, sizeof(st7701_type5_init_operations), true /* BGR */, 10 /* hsync_front_porch */, 8 /* hsync_pulse_width */, 50 /* hsync_back_porch */, 10 /* vsync_front_porch */, 8 /* vsync_pulse_width */, 20 /* vsync_back_porch */);
- Modify the touchpad function according to the pre-set functions in touch.h, and pass the state of the touchpad to the LVGL graphics library.
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
int touchX = 0, touchY = 0;
if (read_touch(&touchX, &touchY) == 1)
data->state = LV_INDEV_STATE_PR;
data->point.x = (uint16_t)touchX;
data->point.y = (uint16_t)touchY;
else
data->state = LV_INDEV_STATE_REL;
To establish a connection between the rotary encoder values and the values of the semi-circle and the labels, some intermediate processing is required.
- Trigger an interrupt whenever the pin ENCODER_CLK changes value, get the value of the counter.Get the value of arc_coun, let the value of ui-Arc1 be changed with the encoder, cycled from 0 to 9
attachInterrupt(ENCODER_CLK, encoder_irq, CHANGE);
void encoder_irq()
State = digitalRead(ENCODER_CLK);
if (State != old_State)
if (digitalRead(ENCODER_DT) == State)
counter++;
else
counter--;
old_State = State; // the first position was changed
void cal_encoder()
USBSerial.print("Position: ");
USBSerial.println(counter);
target_count = (counter % 20) / 2;
if (target_count < 0)
target_count = (counter % 20) / 2 + 10;
if (target_count > arc_coun)
arc_coun++;
else if (target_count < arc_coun)
arc_coun--;
USBSerial.print("arc_Position: ");
USBSerial.println(arc_coun);
lv_arc_set_value(ui_Arc1, (int)arc_coun);
if (label_flag == 1)
_ui_arc_set_text_value(ui_Label1, ui_Arc1, "", "");
if (arc_coun == 2)
if (digitalRead(BUTTON_PIN) == 0)
USBSerial.println("Button Press");
while (digitalRead(BUTTON_PIN) == 0)
delay(50);
label_flag = 2;
if (label_flag == 2)
_ui_arc_set_text_value(ui_Label2, ui_Arc1, "", "");
if (arc_coun == 4)
delay(50);
label_flag = 3;
if (label_flag == 3)
_ui_arc_set_text_value(ui_Label3, ui_Arc1, "", "");
if (arc_coun == 6)
delay(50);
label_flag = 4;
if (label_flag == 4)
_ui_arc_set_text_value(ui_Label4, ui_Arc1, "", "");
if (arc_coun == 8)
delay(50);
label_flag = 0;
_ui_state_modify(ui_ImgButton2, LV_STATE_DISABLED, _UI_MODIFY_STATE_REMOVE);
- Unlock code,the LED will be light
void unlock()
USBSerial.println("Unlock...");
digitalWrite(RX_PIN, HIGH);
digitalWrite(TX_PIN, LOW);
