Vibe feeder (2)
A project log for Colour sorting machine for Lego
Automatically sort random Lego pieces by colour!
robgRobG 11/28/2025 at 09:030 Comments
The new feeder is built and briefly tested:
It works ok:
I think there are two options for faster transport: i) increase the spring stiffness so that the frequency can be increased (more hops per second), and/or ii) increase the 'inclination angle' of the springs so that the hops are directed forwards more, and less upwards.
The resonant frequency of a spring-mass system is calculated by:
f = (1/2*pi) * sqrt(k / m)
The spring constant k is for a flat strip constrained at one end:
k = (E * w * t^3) / (4 * L^3)
m = mass
w = width
L = length
t = thickness
E = Youngs modulus
(This isn't a great model, of course, because the real springs are constrained from rotation too - the brass strip doesn't form a simple bend but more of an 'S' shape. I expect the real k will be a lot higher as a result).
So for a 10mm wide, 30mm long strip of 0.8mm brass (E=100x10^9 N/m), supporting 50g mass, the frequency is 50Hz - not far off the 60 I measured.
To double that, k must be 4x higher. I can either make the springs 4x wider (!) or 59% thicker (1.3mm), or 63% of their current length, i.e. 19mm. Or some combination of the above.
I can't easily increase the thickness, except in multiples of 0.8mm. I can increase the width, but perhaps only to 20mm before they're impractical. I can't really make them much shorter either or else there isn't room for the solenoid.
Let's try changing the angle instead...
Yeah that seems to work and, in conjunction with slightly shorter, wider springs, the frequency is up to about 140Hz. The video shows it easily achieves the target of 60mm/sec. Take away the drive signal and the pieces stop dead.
