We have currently designed the box, and know where to place the latches and brackets
Our design features 2 compartments, the top compartment will hold the arcade machine and will be removed from the bottom section after removing 2-3 clips. The bottom section will be to hold loose parts such as cords, and a load cell. Right new we have designed the actual box along with each piece that will make it up. We are going to laser cut each piece of the box using a laser cutter so we also have multiple layouts of the in 2d.
