This should have its entire own project on HackaDay, and maybe soon it will.
Usually a tube amp needs a high voltage transformer, I decided to attempt something different here since early on I was unsure about the final voltage I would want, as well as wanting dedicated 15V rails for op-amps and other lower voltage circuits.
I started development of a solid state power-supply in 2018. Early on I tried a cheap eBay high voltage module, after destroying two at a very low load I decided to move forward and make my own.
Some of the requirements that developed over time:
- 24V input voltage so I do not need to deal with 120V AC line isolation.
- Variable output voltage: 250-360V, 28W
- Heater Voltage: 6.3V, 3A (With Softstart)
- Negative Bias voltage: -30V
- Op-Amp rail voltages: ±15V
Below is the first revision of the board, it only had a high voltage flyback and a buck converter for the heater. It lacked the 15v regulation and negative bias outputs that I would later want. The layout was not great and I had stability issues due as well.
Lots of engineering, math, testing and measurements later... I eventually ended up with this:
A roughly 60W power supply 88% efficient under nearly full load. meeting all the requirements above. Looking back I would now design the supply to run off of 120V instead of 24V. I would also move to a GaN switching FET. But this works...
