- The MaTouch ESP32 S3 2.1 Rotary TFT with Touch is not compatible with the TFT_eSPI library, so I use the GFX_Library_of_Arduino library instead of the driver.
Since I did not use the TFT_eSPI library, it is needed to delete or comment all the codes related to the TFT_eSPI library.
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
When I use the GFX library, it is needed to define the GFX Library For the Arduino Interface pin.
Arduino_ESP32RGBPanel *bus = new Arduino_ESP32RGBPanel(
1 /* CS */, 46 /* SCK */, 0 /* SDA */,
2 /* DE */, 42 /* VSYNC */, 3 /* HSYNC */, 45 /* PCLK */,
11 /* R0 */, 15 /* R1 */, 12 /* R2 */, 16 /* R3 */, 21 /* R4 */,
39 /* G0/P22 */, 7 /* G1/P23 */, 47 /* G2/P24 */, 8 /* G3/P25 */, 48 /* G4/P26 */, 9 /* G5 */,
4 /* B0 */, 41 /* B1 */, 5 /* B2 */, 40 /* B3 */, 6 /* B4 */
// Uncomment for 2.1" round display
Arduino_ST7701_RGBPanel *gfx = new Arduino_ST7701_RGBPanel(
bus, GFX_NOT_DEFINED /* RST */, 0 /* rotation */,
false /* IPS */, 480 /* width */, 480 /* height */,
st7701_type5_init_operations, sizeof(st7701_type5_init_operations),
true /* BGR */,
10 /* hsync_front_porch */, 8 /* hsync_pulse_width */, 50 /* hsync_back_porch */,
10 /* vsync_front_porch */, 8 /* vsync_pulse_width */, 20 /* vsync_back_porch */);
- Modify the touchpad function according to the pre-set functions in touch.h, and pass the state of the touchpad to the LVGL graphics library.
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data ) { int touchX = 0, touchY = 0; if (read_touch(&touchX, &touchY) == 1) { data->state = LV_INDEV_STATE_PR; data->point.x = (uint16_t)touchX; data->point.y = (uint16_t)touchY; } else { data->state = LV_INDEV_STATE_REL; } }
- Initialising the input device,and we need to associate the encoder with the color wheel
To create a group use lv_group_t * g = lv_group_create(), to add an object to the group use lv_group_add_obj(g, obj), and to associate a group with an input device use lv_indev_set_group(indev, g);
/*Initialize the (dummy) input device driver*/
static lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv);
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = my_touchpad_read;
lv_indev_drv_register(&indev_drv);
// encoder
static lv_indev_drv_t indev_drv2;
lv_indev_drv_init(&indev_drv2);
indev_drv2.type = LV_INDEV_TYPE_ENCODER;
indev_drv2.read_cb = my_encoder_read;
lv_indev_t *encoder_indev = lv_indev_drv_register(&indev_drv2);
lv_group_t *g = lv_group_create();
lv_group_add_obj(g, ui_Colorwheel1);
lv_indev_set_group(encoder_indev, g);
- Encoder pin level change triggers interrupt to change color wheel value
void pin_init()
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, HIGH);
pinMode(ENCODER_CLK, INPUT_PULLUP);
pinMode(ENCODER_DT, INPUT_PULLUP);
old_State = digitalRead(ENCODER_CLK);
attachInterrupt(ENCODER_CLK, encoder_irq, CHANGE);
Wire.begin(I2C_SDA_PIN, I2C_SCL_PIN);
void encoder_irq()
if (State != old_State)
if (digitalRead(ENCODER_DT) == State)
counter++;
else
counter--;
old_State = State; // the first position was changed
void my_encoder_read(lv_indev_drv_t *drv, lv_indev_data_t *data)
if (counter > 0)
data->state = LV_INDEV_STATE_PRESSED;
data->key = LV_KEY_LEFT;
counter--;
move_flag = 1;
else if (counter < 0)
data->key = LV_KEY_RIGHT;
counter++;
move_flag = 1;
else
data->state = LV_INDEV_STATE_RELEASED;
// if (enc_pressed())
// data->state = LV_INDEV_STATE_PRESSED;
// else
// data->state = LV_INDEV_STATE_RELEASED;
- Getting color wheel colous and displaying it on WS2812 LEDs.
#define WS2812_PIN RX_PIN #define NUMPIXELS 20 color_status = lv_color_to32(lv_colorwheel_get_rgb(ui_Colorwheel1)); pixels.begin(); pixels.setBrightness(60); pixels.clear(); pixels.show(); void fresh_led() { if (light_flag == 0) { pixels.clear(); // Set all pixel colors to 'off' pixels.show(); } else { for (int i = 0; i < NUMPIXELS - 4; i++) { // For each pixel... // pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255 // Here we're using a moderately bright green color: // pixels.setPixelColor(i, pixels.Color(0, 150, 0)); pixels.setPixelColor(i, color_status); pixels.show(); // Send the updated pixel colors to the hardware. // vTaskDelay(DELAYVAL); // Pause before next pass through loop } } }
- Setting the timer function
long runtime = 0; long led_runtime = 0; long status_runtime = 0; void Task_main(void *pvParameters) { while (1) { if (move_flag == 1) if ((millis() - runtime) > 500) { fresh_led(); move_flag = 0; runtime = millis(); } if (clock_flag == 1) { clock_status = 1; clock_flag = 0; led_runtime = millis(); } if (clock_status == 1) { if ((millis() - status_runtime) > 500) { int remain_time = clock_count - (millis() - led_runtime) / 1000; if (remain_time > 0) { char c[20]; sprintf(c, "Remain: %4d s", remain_time); lv_label_set_text(ui_Label5, c); } else { light_flag = 0; move_flag = 1; clock_status = 0; lv_label_set_text(ui_Label5, "Close"); lv_obj_clear_state(ui_Switch1, LV_STATE_CHECKED); } status_runtime = millis(); } } vTaskDelay(10); } }
