Hackaday.io Hackaday.io
Sign up Log in
IOT plant monitor
ESP 8266 as plant monitor system.
victorVictor
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.8k views
0 comments
2.3k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 6
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
2.8k
0
2.3k
15
Team (1)
  • victorVictor
Join this project's team
  • store
  • source code for measure and log
hardware
ongoing project
Software
ESP8266 ThingSpeak arduino iot 2017HackadayPrize
Related lists
2017 THP: Digi-Key Parts
Hackaday Prize Entries using Digi-Key parts
This project is submitted for
  • Anything Goes
This project was created on 01/14/2017 and last updated 2 years ago.
Description
ESP 8266 connected to soil moisture sensor.
Data logged to thingspeak.
Another ESP8266 reads data from the Thingspeak and connected to relay for turning on water pump.
Components
  • 1 × Soil moisture sensor fds-100
  • 1 × ESP 8266 http://s.click.aliexpress.com/e/rFE6YRJ
  • 1 × 12V boost converter http://s.click.aliexpress.com/e/EaUrrRz
  • 1 × My IOT board for connecting everything
  • 1 × Plant Any plant you can find at home or buy one.
Project Logs
Collapse
  • New boards
    Victor • 07/13/2017 at 19:56 • 0 comments
    New boards ready. It can read data from GROVE interface and control the pump by relay.
    Can be bought from tindie
    Tindie product
  • Source code
    Victor • 06/21/2017 at 20:02 • 0 comments
    Source code is on the github
    https://github.com/victor999/plant_monitor_esp8266
  • Boards for sale
    Victor • 06/21/2017 at 19:47 • 0 comments
    Board for measuring moisture with FDS-100 (4-20 mA version) or with any I2C sensor can be purchased at tindie
    https://www.tindie.com/products/Cemb/esp8266-extension/
  • Control the pump
    Victor • 06/17/2017 at 10:11 • 0 comments
    Designing the second part of the system: pump controller. The device will receive the data from the Thingspeak and control the water pump.
  • Webserver for parameters
    Victor • 03/12/2017 at 20:26 • 0 comments
    Added webserver for setting parameters for the Thingspeak.
    And most important feature is remote firmware update, by the webpage.
    Useful library is ESP8266HTTPUpdateServer.h
  • Current status
    Victor • 01/21/2017 at 18:28 • 0 comments
    The board is up and running. Sensor output measures by analog input of ESP8266.
    Useful library: thingspeak-arduino
View all 6 project logs
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "IOT plant monitor", please tell us the reason.
Send message
Remove Member
