Pre-release V0.9.5
A project log for PocketPD - USB-C Portable Bench Power Supply
Leveraging the Programmable Power Supply (PPS) of USB PD 3.0 and 3.1 to make an ultra-compact bench power supply
centylabCentyLab 08/04/2024 at 00:400 Comments
Another firmware pre-release (V0.9.5). We now has a Menu to select between different profile! The firmware is still under test for edge cases.
Long press VOLT/AMP button to enter the MENU. If you change your mind, just hold the VOLT/AMP button again to cancel. Use the encoder to scroll through the menu and long press the encoder to select your desire profile.
At Boot, default is still PPS profile at 5V and 1V limit.
