- Define the resolution of the screen.
static const uint16_t screenWidth = 240; static const uint16_t screenHeight = 240;
- Then set the drive pin , the TFT_BLK , and touch pins according to the schematic diagram.
#define TFT_BLK 7 #define TFT_RES 11 #define TFT_CS 15 #define TFT_MOSI 13 #define TFT_MISO 12 #define TFT_SCLK 14 #define TFT_DC 21 #define TOUCH_INT 40 #define TOUCH_SDA 38 #define TOUCH_SCL 39 #define TOUCH_RST 16 Arduino_ESP32SPI *bus = new Arduino_ESP32SPI(TFT_DC, TFT_CS, TFT_SCLK, TFT_MOSI, TFT_MISO, HSPI, true); // Constructoror Arduino_GFX *gfx = new Arduino_GC9A01(bus, TFT_RES, 0 /* rotation */, true /* IPS */);
- Since I did not use the TFT_eSPI library, it is needed to delete or comment all the codes related to the TFT_eSPI library.
#include <TFT_eSPI.h> TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */ tft.startWrite(); tft.setAddrWindow( area->x1, area->y1, w, h ); tft.pushColors( ( uint16_t * )&color_p->full, w * h, true ); tft.endWrite(); tft.begin(); /* TFT init */ tft.setRotation( 3 ); /* Landscape orientation, flipped */
- I need something to help me touch or interact with the screen, modify the touchpad function according to the pre-set functions in touch.h and touch.cpp, and pass the state of the touchpad to the LVGL graphics library.
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data) { int touchX = 0, touchY = 0; if (read_touch(&touchX, &touchY) == 1) { data->state = LV_INDEV_STATE_PR; data->point.x = (uint16_t)touchX; data->point.y = (uint16_t)touchY; } else { data->state = LV_INDEV_STATE_REL; } }
- Connecting wifi and getting NTP.
#define SSID "Makerfabs" #define PWD "20160704" // NTP const char *ntpServer = "120.25.108.11"; int net_flag = 0; int bg_flag = 0; void wifi_init() { WiFi.begin(SSID, PWD); int connect_count = 0; while (WiFi.status() != WL_CONNECTED) { vTaskDelay(500); USBSerial.print("."); connect_count++; } USBSerial.println("Wifi connect"); configTime((const long)(8 * 3600), 0, ntpServer); net_flag = 1; }
- Adjust the angle of the hour, minute and second hands according to the acquisition time.
void display_time() { struct tm timeinfo; if (!getLocalTime(&timeinfo)) { USBSerial.println("Failed to obtain time"); return; } else { int year = timeinfo.tm_year + 1900; int month = timeinfo.tm_mon + 1; int day = timeinfo.tm_mday; int hour = timeinfo.tm_hour; int min = timeinfo.tm_min; int sec = timeinfo.tm_sec; int sec_angle = 3600 * sec / 60; int min_angle = 3600 * min / 60 + 60 * sec / 60; int hour_angle = 3600 * (hour % 12) / 12 + 300 * min / 60; lv_img_set_angle(ui_Image1, hour_angle); lv_img_set_angle(ui_Image2, min_angle); lv_img_set_angle(ui_Image3, sec_angle); } }
- When the screen is pressed to trigger a change in the index value.
#define BUTTON_PIN 6 #define ENCODER_CLK 9 // CLK #define ENCODER_DT 10 // DT void Task_button(void *pvParameters) { while (1) { if (digitalRead(BUTTON_PIN) == 0) { vTaskDelay(40); if (digitalRead(BUTTON_PIN) == 0) { while (digitalRead(BUTTON_PIN) == 0) { vTaskDelay(200); } bg_flag = 1; } } vTaskDelay(50); } } long task_runtime_1 = 0; int bg_index = 0; void Task_my(void *pvParameters) { while (1) { if (net_flag == 1) if ((millis() - task_runtime_1) > 1000) { display_time(); task_runtime_1 = millis(); } if (bg_flag == 1) { bg_flag = 0; set_bg_img(bg_index++); } vTaskDelay(100); } }
- The value of the index determines the change of dial style
void set_bg_img(int index) { index = index % 4; switch (index) { case 0: lv_obj_set_style_bg_img_src(ui_Screen1, &ui_img_bg1_png, LV_PART_MAIN | LV_STATE_DEFAULT); break; case 1: lv_obj_set_style_bg_img_src(ui_Screen1, &ui_img_bg2_png, LV_PART_MAIN | LV_STATE_DEFAULT); break; case 2: lv_obj_set_style_bg_img_src(ui_Screen1, &ui_img_bg3_png, LV_PART_MAIN | LV_STATE_DEFAULT); break; case 3: lv_obj_set_style_bg_img_src(ui_Screen1, &ui_img_bg4_png, LV_PART_MAIN | LV_STATE_DEFAULT); break; default: break; } }
Makerfabs
