I've changed indication that shows either MM:SS format or HH:MM and added few hints on the dial itself. Adds to the character a bit.
Also added more ergonomics by making more ridges on the case to have a sure grip when dialing time into the thing.
So I bodged a 2n2222 transistor with few supporting components so not to burn the GPIO and here it is - his loudness the buzzer, blowing right into the space where battery charger board is located - it has a proper opening to the world for sound to come out to.
And you can't imagine how hard it is to make a picture like this - these fellas do not want to stay in place without some adhesive help, always seeking to reunite with their attractive brethren.
Although the precision leaves something to be desired - i use systick as a primary timing source and it can and will drift a bit. Timer was capped at 24h mark and even then it will probably drift to maybe a minute. It is still completely serviceable for meal preparation timing - no more burnt patties for me, yay.
STM32F103 has RTC and this board also has LF quartz attached to it - so there might be an update to use that as a timing source.
Also there is no power efficiency consideration - CPU is always active, DCDC effectiveness is probably subpar, so 1200mAh, as i estimate, might live for around 8-10 hours best. Though it is a question of when undervoltage circuits will kick in - the battery has one on it, and TP4056 board also has another one on it, so go figure. Maybe another day (probably not because i hate working with MCU low power modes - always break the debugging session or makes you read the documentation properly).
Until then - this is how the project is going to be paused at.
mkdxdx
