Anti-tamper and side channel, glitch, laser, voltage, movie, em dual biometric authentication with secure memory space all types! I
UG-467.pdfDatasheetAdobe Portable Document Format - 907.04 kB - 01/14/2024 at 06:55 |
DS28E84.pdfDatasheetAdobe Portable Document Format - 421.29 kB - 01/14/2024 at 06:55 |
analog-solutions-for-xilinx-fpgas.pdfAD discussionAdobe Portable Document Format - 1.24 MB - 01/14/2024 at 06:55 |
ADSP-BF527_ezkit_man_rev.1.7.pdfAdobe Portable Document Format - 872.11 kB - 01/14/2024 at 06:55 |
MAX32590.pdfDatasheetAdobe Portable Document Format - 474.78 kB - 01/14/2024 at 06:55 |
I have a perfect lab rental property that is a decommissioned communication station end in the fields for this military so you can assure that it's our shielded and it has all the antennas there except for a circular one which was her radio depression direction find it but a crack and can probably do that just as good now however I would like to do phase to raise so you can track and being formed every satellite that passes over and you don't have to have them necessarily tilted maybe slightly you can keep him very low to the ground and aesthetically on a parent because the area I'm thinking of has an incredible view of the horizon and I guess you would have to separate them UHF VHF and get your hearts but I guess we're talking about a couple of thousand transmitters receivers and antennas perfect but you would be able to catch everything plus this place is super secure already and then we could test security procedures test authentication devices tests the commercial birds people are making now on universities to throw stuff on a common bus make actual like evidence chain of evidence kind of following the chips and ICS from their manufactured to win their put in a payload because he's going to be able to like transfer the bus and get to the flight controls inertial wheels or the propulsion systems I don't know the answer I think we should try it out and I think we should do away with passwords this could be a fast prototyping fast iteration laboratory made up of a very select group of highly motivated Young fired up legal age I mean eager Eagles is what some guy told me and zth and the echo Federal polytechnic of those end are the MIT and Caltech of the America and we've got parts of all the dod and nro satellites or neutral but we make great stuff.. Orlikon Sky King that's all serious they bought it that programs in the barrel increases that tungsten spiral shredder! Along with everything that's a part of that system just a guy selfish awesome!! These guys are in every physics journal they just shot 10 GB of data from Burn to the top of the Bernie's out for the laser I mean I only want people who gone to school here who have permits to be here who are domiciled here I want Swiss National professional secrecy to apply I want them to all of the data to be here on our servers and I want everything confidential and outsource absolutely none of it no race to the bottom but fast reiteration fast prototyping and push it markert.. I want people who work as hard as me I also have ideas for protocols and for procedures and for tracking ics for manufactured to put in product to launch in space to use in anything I want to do a software bill of materials for ICS I want a multi-stage multi-type situation that apply to everything where ethical researchers ethical hackers independent security researchers and academics can all follow whichever applies to them and do the right thing easily and not be faced with what we might think is common sense and take the bad path no money is ever worth that path!
Dallas sheets, rough outlines and rough schematics while not releasing everything due to auntie Jennifer anti-clutch and decide Channel attack protections while the encryption and software which runs the interior system shall be made open source. For obvious reasons I want the software and encryption implementation as well as authentication procedures to meet exceed and be thoroughly tested by the community and available to others who wish to implement a similar authentication method and I will seek the listed approvals and compliance standards upon completion of the design and a full workout and testing of the software. The form factor in which I plan to in case and the biometric as well as the specifics of authentication other than the software will be kept somewhat proprietary but I'm not sure if that's even necessary given the fact that I've been thinking about this so long and I have washed every single Defcon black cat hardware Idaho and red the esa NASA ccsds security guidelines and system engineering, I've kept abreast of the progressiveness the current MIT papers which cast out on not complete doubt but possible doubt on a true Ford one way operation as well as just being truly interested in getting rid of passwords because no matter how good your encryption scheme is a bad password which can blow it all and we just can't get over this we need to change stay tuned for additional material and bill of materials. I'm reviewing different ICS and then comparing them to approved lists which is time consuming. I'm also building my own local you run large language model which I'm training on specific data sets relevant to me and then creating specific data sets for certain professions like lawyers healthcare professionals, healthcare institutions as none of these should be exposed to the internet. I also don't want the guardrails on mine unless they're to prohibit or reduce hallucinations as I want to hear all that there is and all the different potential options and commentary. Obviously I'll be loading in all of the NASA ES ccsds and federal regulations pertaining to the subject both at the military and National Security level of the United States Switzerland of the European Union. I'll also be including best practices, PCB design, KICAD 7, FPGA proprietary programming software, as well as data sheets on all the most commonly used and best ICs, and much much more as I just received the funds that are my own I'm investing to create my own locally run large language model which I'm going to merge several other modules and agents. I'm 25 years of experience, medical research degree and the Philosophy degree which frankly the first degree perhaps is the most relevant once you've had the others and integrated it.
II'm forming is this sole proprietorship in Switzerland with the option to go into a general partnership and then into our version of a limited liability organization or at the same time I have a side project which is a nonprofit for the establishment of a makerspace combined with an E-Waste of cycling area as Swiss is probably the best I've ever seen as I've already pulled 20 functional computing systems and SME level switches and manage devices which are soon to become my firewall. I'm glad not to have a static IP because who would want to have their IP known and just take pop shots all day. Anyone in Switzerland who is interested in general partnership or participating in my non-profit I am wide open and I view things as rectangular not as a pyramid. I am a believer in capitalism but in ethical capitalism and that the corporate veil should not protect knowing violations of ethics and that profit above all other should not be a legal necessity giving rise to corporate shareholder suits but as long as a company is making a profit that should be a complete bar to shareholder action for decisions of the management and board which are justified by moral and ethical reasons.
How much is enough and how much is too much doesn't company need so much asset that they can require competitors and others with cash without having to issue additional debt and following that line should they have to walk a very careful line not too violate antitrust due to the fact of their overwhelming market share and there's a company here in Switzerland which probably many of you can did you perform speaking.
It's time for a change and you may not know me by my handle but I worked and was the protege for what the managing partner of waiting case London turned the smartest lawyer he has ever known and my own supervisor which I don't agree with his statement I was just a good learner and I'm curious and I see myself as a lifelong student but referred to me as the second and then the first one we lost him. I've been sitting on the sidelines watching and recovering from enormous trauma but I'm a man of faith and I believe that it's my duty and obligation to use my gifts in a decent way and by securing the internet against malicious persistent threat actors and those who wish to cause harm to others is a decent thing to do as well as doing security research in the area of not only encryption and authentication but RF and other areas as well as running a nonprofit which does upcycling and the creation of a makerspace for both artists and script kitties and script adults alike alike to help guide them and keep them on good path. These large sums of money being dangled in front of these highly intelligent people who may not be aware of some of the more common sensical things we take for granted are potential victims and need to be mentored and made clear taking that money and going down that path is something you never want to do because then they've got you. In addition to that, as one researcher who's working on the command and control service and give a presentation at Defcon 2023, he raised his work on whether or not it has the potential of getting him "vanned"! I have both been a defender and a criminal prosecutor and have seen both sides of the equation and only in instances of violence or the willful act to cause harm to others did I really put the pedal to the metal. On the other side of the equation I knew a person who is a distributor of heroin from a extraordinarily for disadvantaged and almost absolutely impossible situation to get out of we're talking about a fraction of a percent of people get out one example would be a Dr. Hart the first African American tenure professor at Columbia University who is a neuroscientist. He represents a beautiful example of what's possible but it's a rare one and this person I represented was the most kind man to his partner and to his children but for my point of view where he grew up and circumstances that he grew up he had no alternative or very few no matter what he did of getting away from where he ended. The war on trucks is misguided and this was for pillars especially if the practitioners here pay attention to having it evolve with the drug of the time as is written in the policy cleared up the heroin epidemic here in a Flash while America has been struggling and has lost a generation of young people. Other than sweatshirt and I spent most of my career doing extremely high level Global business transactions and that's not just something I'm saying here that's my former boss said (this man is fighting the battle with multiple sclerosis and is a beacon of hope for me), "you got to do things that most lawyers dream of being able to do and very few are able. He's not at all mine and it's not long exaggeration I didn't even know it at the time I was just happy to solve the problems legally being able to rectify the different legal systems and find a legal solution to any problem they threw my direction and I mean they I mean the top 1% or even the top fraction of a percent. I think that the difficulties I face since that time we're due to the fact that I was not gifted with these gifts to do that but to use them in my own unique way. I am on the back side or the upside and recovering from severe complex post-traumatic stress disorder and I have no shame and saying that because the level of trauma I was put through is atypical at best. If these words fall on the ears of someone with the ability and access to financing which could fund a small startup research group, and I even have an abandoned perfect laboratory facility to do the work and of course here in Switzerland with ZTH, UniBERN and EPFL, the recruiting pool is ideal. I'm an overachiever and a creative yet humble and smart individual because I believe that my gifts come from a creator despite all of the cosmological hypotheses, which try very hard to pass themselves off as theories, are nothing more but hypotheses are mere conjecture and they've done nothing to dissuade I believe in the teleological or argument by Design and then a touch of things that have happened to me which for me that I can't prove to anyone else nor do I try could only have happened to the intervention of a creator. I am multicultural and multiface but I have my own while at the same time I think people are Faith have no business fighting each other it's against the others and not the humanist so always ask do, you believe In Love and if the answer is yes that's all you need to know that's good enough.
This is an informal yet also I kind of traditional mission statement and financing proposal because it's not a sound bite and it's not a bunch of Bologna made up for the purpose to try and convince anybody to do something which isn't exactly as I say it here. I have no ulterior motives and frankly I don't need to be wealthy I just need to have enough to live and be happy. I would just like for the remainder of my life to have purpose which is decent helps others and protects the vulnerable which includes our environment.
JLM (NeojhackJD & Aquahood (CH)
So let me know and I'll I'll give you my personal email address if I believe that you're interested sincere and that you're a legitimate person as I may have come to your naive but after having dinner with citizen for almost 20 years and worked in more countries that I haven't you can say that I like anything I have any naivety so don't try. But I welcome with open arms sincere and like-minded individuals and like I said I prefer a very select diverse subject matter experts to fill in the gaps and the initial founders will receive an equal share of the ever-evolving business structure which is currently just a sole proprietorship while my side projects will eventually form into publicly registered nonprofits. I want to make her space and artist/makerspace with mentors, both active and retired electronic engineers and people with experience to help people understand how to use CNCs safely laser cutters and engravers as well as 3D printers and basic coding of microcontrollers fpgas and other devices. That nonprofit could turn into a incubator and I'm open to any and all discussion from any parties willing to work as hard as I do.
This is not a normal time specific statement but I think if you read it as far from being the sound but that you'll feel and understand the sincerity and the honesty behind the words contained hearin.....
