I made an initial development board. This supports both sound-based and accelerometer-based ML tasks. As well as using the LEDs as a color detector. So this is intended to be used to develop and validate the tech stack. And then further cost-optimization will happen with later revisions.
These are the key components
- Microcontroller. Puya PY32F003
- BLE beacon transmitter
- Accelerometer. ST LIS3DH
- Microphones. Top-port or bottom-port MEMS, or external electret capsule
- Battery charger for LiPo/Li-Ion cells
- USB Type A connector for power/charge
Using a pre-built and FCC certified module for Bluetooth Low Energy, the Holtek BM7161.
This is a simple module based around the low cost BC7161 chip.
An initial batch of 10 boards have been ordered from JLCPCB.
Also did a check of the BOM costs. At 200 boards, the components except for passives cost
- With microphone: 0.66 USD per board
- With accelerometer: 0.825 USD per board
Additionally, there are around 20 capacitors, 1 small inductor, and 20 resistors needed.
This is estimated to be between 0.15 - 0.20 USD per board.
So it looks feasible to get below the 1 USD target BOM, for as low as 200 boards.
Also designed a small 3d-printed case, with holes for the microphone and LEDs / light sensor.
