The lion kingdom once made a foot pedal shutter control. 10 years later, there was finally a need for it.
Then came another idea make the foot pedal wireless. The foot pedal camera controller lions made many years ago worked with the EOS 5D but not the RP. The mane problem is the Yamaha pedal is open in the down state & closed in the up state. It needed an active circuit to invert the voltage.
The RP shutter pins no longer have enough pullup current for a self powered circuit. There were 2 more xbee pro's. There were enough spare parts to bodge something together.
It's unfortunate that the unplugged state is the down state for the Yamaha pedals. The user has to remember to connect a jumper when no focus pedal is connected & disconnect the jumper when a focus pedal is connected. Ideally, there would be a single pedal with 2 positions. You're in a world of hurt without a 2 position pedal.
