Here is the completed PCB; I soldered all the components using solder paste and a soldering iron.
Next stage is to wire up the JST SH plug.
A project log for Gentle Typing Trainer
Uses piezo sensors under your keyboard to sense harsh typing and warns you with the flash of a LED. Helps to guard against OOS.
