The first thing I did to this was to get rid of batteries. I used some scrap wood with a screw in the end for a battery stand-in. Here you can see the positive and negative connections made in the original battery slots. The only alteration to the exercise machine is a slot cut in the battery lid for the wire from the wall wart to exit.
Mike Szczys
