Mechanical Parts and Assembly
https://github.com/StefansAI/JetCar/blob/main/docs/Assembly.md
The documentation in GitHub and Video 1 starts with the mechanical design of the car itself in Fusion360 and goes over the assembly of the 3D-printed parts (Video 2). The files for all parts are available for download here: https://github.com/StefansAI/JetCar/tree/main/mechanical
SD Card and Firmware Setup
https://github.com/StefansAI/JetCar/blob/main/docs/SD%20Card%20Setup.md
GitHub and Video 3 describe how to download the NVIDIA JetPack SDK for the Jetson Nano and run the install script on the Nano to install everything needed. (https://github.com/StefansAI/JetCar/blob/main/firmware/install.sh)
Data Preparation with ImageSegmenter
https://github.com/StefansAI/JetCar/blob/main/docs/Data%20Preparation.md
The ImageSegmenter application for the PC was written to manually mark classes in recorded camera images and to create augmented datasets from it for the training (Video 4)
The executable can be downloaded here: https://github.com/StefansAI/JetCar/tree/main/tools/bin/ImageSegmenter and the full source code can be found here: https://github.com/StefansAI/JetCar/tree/main/tools/source/ImageSegmenter
Model Training
https://github.com/StefansAI/JetCar/blob/main/docs/Model%20Training.md
GitHub and Video 5 describe the training in Colab. The training notebook can be downloaded from here: https://github.com/StefansAI/JetCar/blob/main/tools/pytorch_unet_mobilenetv3_colab_catalyst_20.ipynb
A fully trained model file example, ready to be used is here: https://github.com/StefansAI/JetCar/blob/main/firmware/jetcar/notebooks/JetCar_Model_MobileNetV3_Medium_Map_Traing_N19.pth
StreetMaker Application
GitHub and Video 6 describe the provided PC application called StreetMaker. It allows designing and printing a street map for the car to drive on.
But this application has added features to create virtual camera images of the map together with the class code mask and augmented datasets for the training. The predictions from the training notebook can be viewed together with the input.
The executable with 3 example maps can be downloaded here: https://github.com/StefansAI/JetCar/tree/main/tools/bin/StreetMaker and the full source code here: https://github.com/StefansAI/JetCar/tree/main/tools/source/StreetMaker
Firmware and Debugging
https://github.com/StefansAI/JetCar/blob/main/docs/Debugging.md and Video 7
The firmware is written in Python to run under a Jupyter notebook on the Jetson Nano. It contains only few files named here:
The files can be found here: https://github.com/StefansAI/JetCar/tree/main/firmware/jetcar/notebooks
In short: The mask is passed on to the LaneTracker object, which first finds the lane limits and then the class codes in own lane and the lanes left and right. LaneCenter extracts run-length coded object lists to track arrows, texts and turns.
Since debugging a system in real-time id difficult, the driving notebook has a recording feature that allows storing all camera images together with the mask from inference and a log file in a special folder, that can be zipped up and downloaded to the PC. A Visual Studio Code offline debugging environment is described how to go through each frame and mask stepping through the firmware code or simply how to enable all the different print outputs variables to analyze the output log.
The offline debug files are located here: https://github.com/StefansAI/JetCar/tree/main/firmware/offline_debug
Operation
Video 8 of the series below demonstrates how the JetCar is navigating the printed out street map, how it stops at any intersection with stop text and stop line and how it obeys the arrows, ignoring turning requests that are not allowed.
Here are the links to the mini-series of 8 videos available in YouTube.
JetCar Part 1 - Introduction:
... Read more »
Stefan
Razvan Pop
repeatedfailure
likeablob
Olda
