The delta calibration guide for klipper recommends a 0.025 mm consistency or better for automated probing. Testing of this probe location bias on my FLSUN QQ-S Pro with the stock magnetically attached probe showed the bias was at least an order of magnitude higher. A concept was developed to retain a 15mm x 15mm copper pad under the nozzle. As the nozzle lowers the pad will first contact and become parallel with the bed prior to the nozzle touching the pad. The design was refined to use a 40mm x 40mm foam pad and 2nd copper shim to basically make a 5mm thick sheet of paper.
mulcmu
Tyler Anderson
Dominik Meffert
Daniel Westhof
