Non-Suleiman Version
After my last post I realised I did not need Suleiman's code. The Newton-Rapson method could solve the "t" values directly, but it would likely need more iterations.
Here are the results:
So the results are indentical which means my derivation (based on first and second derivates) is but a refactorisation of Suleiman's.
BezierFitV2.c is in the files directory.
