The M-BUS Master Wing can read consumption meters for heat, gas, oil, water etc. that have a built-in M-BUS slave interface.
Features:
- M-Bus (meter bus) Master
- powered by an external 9..30V DC voltage (36V for the MBUS will be generated internally from this voltage)
- up to 6 unit loads can be powered
- isolated interface
- can be combined with any Feather shaped microcontroller board
Application:
