Even if the code is compatible with early version of minitels, the cartridge needs to be powered from the DIN port to works. Unfortunately not all minitel provides that power source.
The table hereafter is extracted from STUM 2. Not sure how to recognize the minitel model visually, but this is a good start to check which minitel are compatible !
