A quick video demo
Table of Contents:
Hackaday dot io single-page view mode gets a bit unweildy for a project of this size, so here's a table of contents:
The most up-to-date design and fabrication files are in the Codeberg Repository
You can buy an assembled Version 2 driver board on Tindie.
Project Logs document my journey of making this whole thing happen, including quite a lot of learning-process failure. Link opens in chronological order.
Details (this section / link opens page standalone) has video showcases, a walkthrough of the primary "class E" driver, and an overview of the system as a whole.
Instructions features overall recommendations for creating your own plasma toroid, component selection tips, and some notes on replicating the Version 1 build.
Files is OLD/ARCHIVED version 1 design files. and LTspice simulation files
Log #11 covers deficiencies in Version 1, and areas for potential improvement.
Log #14  is an overview of improvements made in Version 2.
Full Video Showcase:
How does the driver work?
Steve Ward explains the circuit's function in terms of what happens on each cycle. That can be a useful way to think about things, but for myself I gained far more intuition about how things work by deconstructing the entire resonator into a series of functional building blocks.
Let's start simple -- take some voltage in (V1), put an inductor (L1) in series with an N-channel mosfet (U2), and feed the mosfet a square wave at some frequency. Areas of the circuit have been highlighted to correspond to the LTspice simulation traces. (Don't worry too much about the specific values on each axis; the overall shape of each trace is more important.)
It's a boost converter!
While the mosfet is conducting, current flows through L1 and builds up a surrounding magnetic field. When the mosfet turns off, this field tries to keep shoving current through L1, resulting in a spike in voltage.
The next building block the beating heart of this project -- a resonant LC tank circuit formed by our primary inductor and a small bank of high-voltage capacitors (Cp).
In this classic LC Resonator tank circuit, energy sloshes back and forth between the electric field in the capacitor and the magnetic field around the inductor. This resonator tank is being fed by the voltage spikes created by L1.
If the tank is driven by a frequency that's well-matched to its natural resonant frequency  1 / ( 2pi √(LC) ), total energy in the resonator accumulates and can greatly exceed the input on any one cycle.  The primary inductor's substantial electromagnetic field will excite our xenon.
Trying to precisely match the resonator and gate drive frequencies to match each other sounds annoying and fiddly, so let's use a feedback network instead.
Adding a capacitor Cg (between Cp and ground) forms a capacitive voltage divider. This drives the gate at exactly the natural resonant frequency of the tank circuit. Now the tank is oscillating at 9 amps and (peak-peak) 2.4kV!
Since a capacitive voltage divider only responds to AC, the DC component of the gate drive is set by connecting some bias voltage V(bias) through a resistor. The value of Cg is chosen such that the AC amplitude at the mosfet gives solid turn-on / turn-off without exceeding operational limits, and the mosfet duty cycle is determined by where V(bias) positions this waveform relative to the mosfet's gate threshold voltage.
Rather than plonking down a magic reference voltage for V(bias), let's instead pull a voltage divider down from our supply voltage.
In a physical circuit, let's make R2 a potentiometer so we can freely adjust V(bias) while the circuit is in operation.
The only thing left is to fine-tune the gate drive!
For the real circuit, it is very important that mosfet turn-off occur when the drain voltage is at a minimum, aka "zero-voltage switching" (ZVS) or "soft switching". This is complicated by the fact that the mosfet has non-neglectable internal parasitic capacitances between each of its pins. In particular, any residual energy stored in the internal capacitance C(oss) is shorted through the mosfet body at turn-on.
Lots of circuits do just fine without soft switching, but it's more typical to drive mosfets with a square wave which reduces switching losses. We're also running at >10MHz though, so even a few microjoules of lost energy per cycle can result in the mosfet soaking up tens of watts worth of waste heat. Additionally, hard switching can cause drain and/or gate voltage ringing which isn't ideal either. These effects are more than capable of causing the mosfet to self-destruct.
R(g) creates an RC circuit which introduces a phase delay on the gate. This is in addition to the phase delay cause by the time taken to charge the mosfet parasitic gate capacitance. The exact value needs to be tuned to the as-built circuit -- 2.2Ω is a placeholder. R(g) also adds some dampening to any parasitic ringing in the gate feedback network.
A pair of 15V zener diodes (highlighted orange) prevent gate voltage from overshooting operational limits (the exact component displayed here is also a placeholder).
This model circuit is almost identical to the one shown in BacMacSci's plasma toroid, but with the diagram rearranged for clarity.
The additional 10nF capacitor (labeled C3, highlighted blue) locally decouples any back-propagating ripple voltage on the gate bias.
Here's how the [VERSION 1] driver circuit is actually implemented, with real component values
The primary capacitor is split out into a bank of four to help distribute heat. Similarly, two MOSFETS are arranged in parallel, and their gate resistors are paralleled again (they get hot at low bias voltages). Diode D5 helps stabilize/regulate the bias voltage.  A large heatsink and fan is required to keep the driver cool.
The part of the circuit inside the dotted line is an wirelessly coupled inductive coil. It's used to drive an indicator LED showing whether or not the circuit is in oscillation. Development details are in the update log #6: Status LED, galaxy brain style.
How does the [VERSION 1] arc start module work?
The electromagnetic fields generated primary inductor aren't strong enough to ionize neutral xenon gas into plasma. Instead, initial ionization is accomplished by creating a very brief high-voltage pulse on a fly-wire contact, which capacitively couples through the glass.
My approach to arc start is conceptually similar to what's used in xenon flash lamps. BigCliveDotCom has a great video on how xenon flash lamps are fired, titled "Unwinding a tiny 6kV xenon trigger transformer".
The shortest version is that a small capacitor is charged to the neighborhood of 300V, then rapidly discharged through the primary of a high-turns-ratio transformer. This creates a very high voltage pulse on the transformer secondary, which is fed to a fine wire wrapped around the glass of the xenon flash tube.
In my case, the high voltage causes capacitive coupling to the xenon through the dielectric of the glass, strong enough for ionization.
Here's my implementation:
In my case, I'm using an off-the-shelf LT3420 photoflash charge IC + flyback transformer to generate >470v output, pretty much exactly per its datasheet reference circuit. This charges a 47nF trigger capacitor (C6).
Typically, a silicon-controlled rectifier (SCR) is used to switch the trigger pulse. However, I found in bench testing that the strong EMI coming off the main driver's primary inductor was causing premature triggering. Instead, I'm using a device called a gas discharge tube surge arrester (shown as GD1 in the schematic). Functionally, this behaves like a spark gap which fires at a specific design voltage.  Since I just need the trigger to fire at sufficient charged voltage but don't care exactly when the trigger occurs, this is perfect.
More information and design process can be found in project log #7: How to ionize xenon -- the arc start module.
The Circuitboard
Many of prototype boards in this project -- as well as the final (V1) project board -- have been sponsored by PCBWay! More details are in each of the relevant project logs.
