I spent some time playing around with 3D printed bezels again - this time, printing the diffuser as well as the bezel. You can see the results: no bezel/diffuser (top), white bezel/white diffuser (middle), black bezel/white diffuser (bottom). You lose some brightness with the black bezel, but the overall effect is much better because it really kills the light bleeding.
The diffuser is a single layer of 0.2mm white PLA+. The bezel (square cells) is printed directly on top of the diffuser layer. For white/white, it's just a single print, but to get the black bezel on a white diffuser, I had to make two separate-gcode files, and swap filament in between printing them. It's a little bit of a pain, but the result works pretty well.
Here, I'm purging any white filament from the hotend after printing the diffuser layer and loading the black filament:
Next, I run the bezel g-code to construct the cells right on top of the diffuser:
The result is a single piece which fits over the 0603 LEDs (on 0.1" centers):
Like the previous experiments with 3D printed bezels at this scale, normal slicers just don't cut it :-) I had to generate the g-code to print these using a python program. After you get started, though, it's pretty cool what you can do by putting down a few hundred microns of plastic exactly where you want it.
I think I'm going to expand the code to add brackets to mount the bezel to the PCB holes. More python -> more g-code -> more melted plastic.
I like the "bloom" effect of the white/white bezel.
in person, it looks like a defocused analog oscilloscope - but there's no focus knob!
Yeah, looks like the old phosphor screens... Btw, I've used your VEML7700 arduino library, and it's been nice to have. Thanks for coding that up!
Are you doing "Life" on that display ;)
That's a really impressive diffuser/bezel result.
yep, it's life
https://youtu.be/u26hTV89_7Y
The diffuser works great, but in bright light, the contrast isn't ideal since the white diffuser reflects a lot of ambient light. I'm going to try to print the whole assembly on top of a green filter next. If the print will stick to it, that should improve the contrast.
