Full scale test of the rover test bed using simulated moon regolith and rocks. The rover did very well at powering though at 40% motor speed. Was a big hit at the local robotics club. More to do on the hardware of the rover still. Though initial test went good.
Also designed and 3D printed a lunar regolith recovery scoop, worked pretty well for packing it back up. :)
