Hello together,
Here you can find the necessary files to create your own boards. Since the design is two layer only it is possible to CNC the boards. You should only take care to isolate the back of the board where the scale is sliding with some tape:
Here is the link: https://github.com/MitkoDyakov/Calipatron/tree/main/Hardware/V1.2
You will find:
- gerber files
- POS files
- Schematics
- mounting diagram
- BOM
- KiCAD footprints
- step models
- 3D renders
If you like the project and you want to join now is a good point. Still the project has a long way to go and it could be improved, but I feel the HW is in a working state and could be used in POC for your intended use.
Cheers,
M
