Hello all,
I decided to add a twin-t notch filter between the op-amp and ADC input of the MCU. This is the schematics of the filer and values used:
I build the on a proto board, cut the trace between the op-amp and MCU and connected everything together, with thin wires.
And running the software from the repo, we get the following results on the Serial Oscilloscope:
I think this is quite workable. From now on I think it is battle with the software :)
**But thinking more and more we need to count pulses anyway. If we write the software cleverly enough we might get away even without the filter.**
Cheers,
M
