Bottom Line Up Front
The Microcoin QL uses pin 6 for an inhibit function. Their tech note says ground the pin, still no joy.
TL;DR
The company’s tech note describes pin 6, Vinhibit. See below. By default, the pin is floating, the default way most of us would connect the acceptor and get it enabled. But no luck. So I tried Ground, still no joy. I even tried positive voltage, but certainly did not believe at this point. Here's the excerpt for pin 6:
Spoiler alert: There’s more to the story and use of pin 6. The acceptor activates when pin 6 is grounded and the acceptor is constantly polled. And for that to happen, the adventure transitions to ccTalk and commands sent over its data line.
