Chip-8 Interpreter is working
A project log for Tjipp8 - A Chip-8 game console
A low part count PIC16F1705 game console for the ancient (1970's) Chip-8 bytecode interpreters originally run at the Cosmac 1802.
matsengmatseng 01/24/2017 at 07:198 Comments
I spent some hours coding up the Chip-8 interpreter and got most of it implemented very easily.
But I still have to take care of the problem with the Chip-8 applications running from flash, thus preventing the applications to use unused parts of the 4K area as extra variable storage. Basically I just have to implement a lookup table pointing to the PIC's SRAM area and use that whenever a read/write to the Chip-8 area is detected. This is probably a few hours of coding and debugging - but that's things one have to accept when selecting the "wrong" hardware for a project. :-)
This is the classic MAZE demo running:
Rich text editor
coletonn wrote 01/24/2017 at 17:28 point
That's some old stuff man.
matseng wrote 01/24/2017 at 18:05 point
sure is.... Of you actually every used a computer with chip-8 when is was invented you'd have a gray beard by now since you would be at least 50 years old... ;-)
Aleksandar Bradic wrote 01/24/2017 at 17:24 point
Awesome! btw there's a very interesting book on this maze: http://10print.org/
matseng wrote 01/24/2017 at 18:07 point
Nice! Downloaded for reading next weekend when I'm flying down to Kuala Lumpur. Will have some hours at the airport and another two at the flight to kill.... Thanks.
SHAOS wrote 01/24/2017 at 14:21 point
cool
Eric Hertz wrote 01/24/2017 at 08:32 point
Wow, that maze is pretty cool for a mere 64x32!
matseng wrote 01/24/2017 at 12:05 point
Not only that. Whats really amazing is that it's only 15 lines of Chip-8 code plus 8 bytes of of graphic images! They for sure knew how to make a lot with little back 30-40 years ago.  The entire Chip-8 interpreter code fit into 512 bytes of Cosmac 1802....
https://github.com/badlogic/chip8/blob/master/roms/sources/MAZE.SRC
Eric Hertz wrote 01/24/2017 at 12:43 point
Very cool, thanks! I implemented it in C just now, doesn't look nearly as cool in ascii ;p
