1×
XIAO ESP32 C3
The XIAO ESP32 C3 is a development board designed for hobbyists and makers who want to create Internet of Things (IoT) projects. It is based on the ESP32-C3 microcontroller, which is a low-power, Wi-Fi and Bluetooth-enabled chip from Espressif Systems. The XIAO ESP32 C3 board is small and lightweight, making it ideal for portable projects. It also has a built-in USB port, making it easy to program and debug. The XIAO ESP32 C3 board is a great choice for beginners who want to get started with IoT development. It is also a good option for experienced makers who want a powerful and versatile development board for their projects.
1×
DHT11
The DHT11 is a basic, ultra low-cost digital temperature and humidity sensor. It uses a capacitive humidity sensor and a thermistor to measure the surrounding air, and spits out a digital signal on the data pin (no analog input pins needed). Its fairly simple to use.
1×
0.96 OLED Display
A 0.96-inch OLED display is a small, organic light-emitting diode (OLED) display that is commonly used in various electronic devices and IOT projects. .
1×
jumper wires
Used to connect the above components.
