During daylight saving I noticed it was not very convenient to have the timezone in the same menu as the time. You would have to enter through 6 steps to only change the timezone. To make this easier I moved the timezone to a seperate menu item in the settings screen.
Timezone in the settings
I also made it store the last viewed token. On bootup it reads the last used token and shows this instead of the first token. This makes it quicker if you want to enter the same 2fa token multiple times.
