​Linear Rail
A project log for AutoFold the Box Folding Robot
We are creating a system to automate the process of folding boxes
fourthlevelmfgFourthLevelMfg 02/28/2017 at 08:480 Comments
The plan is to use this Linear Rail design for almost all steps of the folding operation. We can easily change the length of the rail by cutting the V-slot, and using a shorter Ballscrew. The clear plastic piece is the standard base for the 3D printed box-interface-parts. Its removable from the cart with 4 bolts. The cart is built on a single 1/8 metal base plate that requires no bending. The plate that the stepper bolts to with the long brass stand off's is also flat 1/8 in metal with no bending. Meaning If we order a large batch form the machine shop it comes out to only a few dollars a piece if cut with high power laser. >=D we plan is order a large batch of these plates and sell the rail kit on Amazon for people who would like to make their own.
1x NEMA 17 steper
1x 250mm 8mm BallScrew
1x 250mm V-SLOT rail
4x V-slot Wheels kit
4x 40mm m3 standoffs
1x stepper ball screw coupler.
2x 1/8th plates
and all the hardware.
Thanks -Jake C
Rich text editor
