This is an animation of a V slot maker that uses wood instead of aluminum. The Idea is you can quickly prototype with wood and then switch to aluminum if necessary use. It makes 20mm V slot out of 1in square wood. (914.4mm) 36 in. x 1 in. Hardwood Square Dowel is $3.42 Home Depot vs 1000mm 20mm 20mm vSlot $20.28 with shipping.
