Ahh man, 10 hrs later the decision to print with the front up ended up being bad... it looks good but it broke the seal/makes it look bad... oh well.
Still... I am pretty pleased with it, it's bulky and it has a tripod attachment, large screen.
Ugh... I should not have used hot glue, I knew it would be ugly.
But it works
See the v2 module vs the HQ cam
The side profile looks good, it's beefy
I did not have time to work on the code so I'll have to put time into that
It has to detect which camera so that if it is for example the V3 module, it can do electronic aperture change
Yeah I am pretty pleased with the performance of the V3 modules so it'll be nice to switch between them and the wide one with the same camera body.
I'll post the videos when they're done processing.
Swap cameras
Devlog
