Getting straight to the core to try to explain it simply, the anwaar amulet is a 2 piece design.
The bottom board (I refer to them as the base board) can be thought of as a hyper specific development board. In this case I ended up using an attiny 1616. On top of that it also includes an energy source (15F Hybrid Capacitor) as well as all the power management for charging and providing a stable VDD rail.
The top board (which i refer to as the face plate) connects to the base board using a 10 pin header/socket and secures with five m.2 screws/standoffs. The face plate is intended to carry artistic designs and circuits, the obvious use being a fun blinkies. Taking it a step further I like to find ways I can integrate the copper of the circuit into the artistic design itself!
Bulbul
Some explanation on the pictures. The only surviving one of these I still have! The goopy look was from me experimenting with conformal coating. You can see I even spelled hyat wrong! (حياة) ! I was just getting into learning arabic at the time (still have a long ways to go!). Not pictured are the standoffs which were standard threaded hexagonal standoffs, and the hybrid cap which was harvested and reused on other boards.
greg
Tony
fool
