After having a PV Electric system installed, I wanted a simple way to monitor the system. There is a Web Page dashboard, the there is an App for my phone. None of that addressed my "at a glance" status of the system. I wanted a way I could look up and see how things are doing.
At the same time, I didn't want to setup a monitor, with a Raspberry Pi or something and show the Kiosk page for the panels. Adding a power consumer like that sounded antithetical to the project of adding Solar Panels to the house.
I want a simple, low power display that can update over WiFi.
I was having great success with the basic request for the current status. Things were working great. I wanted the 15 minute updated production history. This required a start date time and an end date time.
Every time I attempted to call that API it would yell at me. It worked fine in Postman, but the ESP32 would generate a 400 error at the web server.
The problem came down to dates. A lot of API's use a date format like YYYY-MM-DDTHH:MM:SS.sssssZ. The Solar Edge API use YYYY-MM-DD HH:MM:SS. The first format and variations of it are more common today. The issue with the date format used by Solar Edge is that it requires that you replace the space with a %20.
Postman makes this correction automatically, but in the ESP32 code, you have to remember to swap any spaces in the query string with %20 characters. This easy to overlook requirements is why first example with a T separating date and time is more common.
To any aspiring web service developers out there: Query string parameters requiring spaces should be avoided.
On a whim I decided to put a LILYGO T-Display S3 into the mix and see if it didn't behave better. The code shouldn't require a change between hardware platforms thanks to the hardware abstraction layer in the Arduino development platform.
I hit upload and POOF, worked first try. There is something amiss in the Pico implementation of WiFiClientSecure or some other related library. I wanted this to be a Pico project, but an ESP32 project is just fine.
Calling a Web Service isn't too difficult and with the SolarEdge documentation and Postman I was about to talk to the system right away. Really easy API Key based system. I would feed the same API calls into the Pi Pico W and it would scream about security. I had to go with a .setInsecure() command on the client to get any response.
When it did respond, out of the entire JSON datagram all I got was the first "{" and it would hang. Very frustrating.
I have a Photovoltaic Solar Array on my roof, and as a nerd I just can't NOT know how it is doing up there. Bureaucracy being what it is, it was installed in the summer, and I didn't get Permission to Operate from the local electric company until late November! Located in the snow-covered wasteland of Hoth, my daily entertainment has been watching the daily production climb as we start to see the sun again.
The problem is that the only way to view the production is via a web page or phone app. Being the ADD person I am, every time a ray of sunshine came through my office window, I was drawn to open the app or load the dashboard web page. Leaving the dashboard up on a spare monitor and a Raspberry Pi just didn't feel right, spending all that electricity to watch my electricity production.
I do have is the SolarEdge API documentation and a Pi Pico W unit. The adventure begins.
