Same deal as the Aria project only a different name, Vento is Italian for Wind, continuing the naming theme. The board differs by using the ESP32 for both WiFi and BLE. Developed at the same time as Aria and has been open from the start just finally sharing it now. Feel free to give feedback and have a look at the source. Designed in KiCAD using the nightly build so if it doesn't open in the stable that's why.
You know the drill, more to follow when I stop spreading myself too thin :)
