This unfortunately took me way too long.
I kept running into this problem:
A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out) Failed uploading: uploading error: exit status 2
In the end I got past it by using a Linux laptop eg. Ubuntu on my Carbon X1 gen 6.
I was trying to program it on my MBP i7 2015 with Monterey... dumped like 3 hrs into this damn.
But I was able to flash their demo code.
With this I'll be able to read through their code and make my own UI to talk to the RPi.
I have to look into pairing the two with serial that would be ideal vs. just button events via GPIO (eg. high/low)
Hi Jacob, thanks for your sharing, can you tell me how to come over the problem?
I also working on the same macbook like yours and got the same issue :(
