Well, initial testing was more difficult than expected - took about five hours just to get a couple of basic circuits working. Made a number of incorrect assumptions / mistakes including:
- Assuming it might be differences between components (germanium vs. Silcon, transformer winding ratio, meter current)
- Blaming the jumper wires (a bit old and janky)
- Rushing too much when making the circuits
Finally found out my resistor board PCB traces had not been routed 100%. Yikes! After re-soldering the board a couple of the projects are finally working. Next step is to get a number of them fully tested and documented...
Project # 1 test - tone generator :-)
