The PCBs are finally finished! I used different color solder masks to capture the look of the original kit. I will be uploading the Eagle files and BOMS shortly.
Tiffany has designed a panel and enclosure she is finalizing this week. More photos coming soon!
The manual is in process but will take some time as every project needs to be tested and documented for accuracy.
