I have done a second calibration on both the full featured multimeter version, and the voltmeter version after ~1 year. No adjustments were needed. I have backed off the voltage spec to 0.5% relative accuracy. Both versions showed slightly higher error when measuring 1V compared to the first time I calibrated them. This leads to a large decrease in accuracy. 1V is low in the voltage range, so small differences lead to large errors.
schuyler4
