REV3 Prototype
A project log for Multimeter
This is my homebrew multimeter design. Included modes are VDC, Ohms, and Capacitance.
schuyler4schuyler4 09/30/2025 at 02:500 Comments
The prototype for REV3 has been constructed.
Unfortunately, there seem to small memory effects with the voltage reading after increasing the input impedance to 5.21M ohm in this revision. I'm going to attempt to create an auto zero circuit to compensate for this. In addition, there are a routing issues, and additional IO is really needed, as in this revision the LED pin on the pico board is used.
